Activity Forums Blackmagic Design MBe and DVI
  • MBe and DVI
    Posted by Kaspar Kallas on March 2, 2006 at 4:45 pm
    Hi
    first off the interlkaced mode in HD is prefect! THANK YOU!
    but there is a problem interlaced or not when using apple monitor and scaling SD footage lower third of the image seems one firame behind after after evry other 2 or 3 frames if interlaced mode is disable – resulting rather wierd strobe effect.
    The same thing does NOT happen in NTCS frame rates
    -Kaspar
    Kaspar Kallas replied 20 years, 6 months ago 2 Members · 2 Replies
  • Kristian Lam
    March 3, 2006 at 12:14 am
    Hi Kaspar,
    We’re aware of this issue and it should be fixed in our next driver update.
    regards
    Kristian Lam
    Blackmagic Design
  • Kaspar Kallas
    March 3, 2006 at 6:06 am
    good to hear!
    -Kaspar
