Activity Forums Blackmagic Design MBE Analog HD to SD-SDI Possible?
  • MBE Analog HD to SD-SDI Possible?
    Posted by Chris Borjis on August 17, 2006 at 12:08 am
    I also dropped a line to blackmagic about his but,
    I’m trying to do a real time hardware conversion
    with the multibridge extreme in down converter mode.
    I want to go from a jvc hd100u HD component out to
    the analog HD component in and ouput to channel A or B
    SDI-SD in realtime.
    This does not seem to work.
    DVI-D will output to my Dell LCD, but I get snow on my SD-SDI sony monitor.
    What I’m effectively needing to do is hardware downconversion from the JVC HD signal to SD-SDI for my DigitalBetacam deck.
    Chris Borjis replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
