Activity Forums Blackmagic Design MBE – 10bit easy setup – field dominance problem
  • MBE – 10bit easy setup – field dominance problem
    Posted by Rafal Szermanowicz – grupa #13 on August 23, 2006 at 8:59 pm
    Hi.
    I captured over 4 hours of footage via SDI form DigiBeta(PAL) deck. I decided to capture using 10bit easy setup. Everything looks great but…
    – I noticed that field dominance is set to Upper…why ? (I`m working in PAL system)
    Here`s my problem. When I`m editing in 10bit sequence image is great but after exporting to DV PAL file I have problems with slow-mo – it looks like wrong field order – only on slow-mo footage…also using compressor for example mpeg file looks the same…..
    Any ideas what`s wrong ?
    http://www.grupa13.com
    Chris Borjis replied 20 years ago 4 Members · 4 Replies
