Activity Forums Blackmagic Design MB Extreme – SDI Out Options dissappeared need fix now.
  • MB Extreme – SDI Out Options dissappeared need fix now.
    Posted by Chris Borjis on February 19, 2007 at 10:31 pm
    Kristian,
    I just also sent you an email.
    I downgraded the drivers (i did uninstall first)
    That did not fix the double edge/combing effect on 720P monitoring via dvi-D.
    Not only did it not fix the issue, my SDI output is no missing from my output options.
    I can’t edit to digibeta.
    This is a major problem that needs a fix right now as i have clients booked this week.
    Chris Borjis replied 19 years, 7 months ago 2 Members · 2 Replies
  • Kristian Lam
    February 20, 2007 at 9:18 am
    Thanks for the email informing me that the issue with no SDI output is due to a cabling mixup.
    Please also let me know if going back to a previous driver fixed the issue with 720p monitoring.
    regards
    Kristian Lam
    Blackmagic Design
  • Chris Borjis
    February 22, 2007 at 1:24 am
    I emailed you back.
    It had no effect and I now do not believe it was the firmware that broke it.
    I believe it just is not working hdmi out because the one time I looked at it on the plasma it was via component.
    unfortanetly component is now hard wired to our dvd player.
    The heart of the matter is 720P uncompressed or hdv doesn’t matter, will not playback properly out of dvi-d hdmi to our plasma.
    Thats what needs to be fixed.
