Activity Forums Blackmagic Design MB Extreme display on a MacPrp 8 core
  • MB Extreme display on a MacPrp 8 core
    Posted by Wilson on August 18, 2007 at 10:53 pm
    We are about to run a MultiBridge extreme that was originally purchased to run on a Power Mac G5 dual core 2.3 on a MacPro 8 core. Are there any issues we should be aware of?
    Ian
    Kristian Lam replied 19 years, 1 month ago 2 Members · 1 Reply
  • Kristian Lam
    August 19, 2007 at 11:44 pm
    Hi Ian,
    Make sure you use the top slot in the Mac Pro. Upon installation, the Expansion Slot Utility should pop up when you stat up the Mac. This allows you to configure the lanes of the PCI Express slot. We’ve seen instances where that does not happen so launch “Expansion Slot Utility” located in “/System/Library/CoreServices” and select profile number 2.
    regards
    Kristian Lam
    Blackmagic Design
