Activity › Forums › Adobe After Effects › Maybe you could do this for the next tutorial?
Posted by Ryan Dixon on January 31, 2009 at 3:54 amHey i was looking around trying to find some cool effects for some videos im making and was wondering if someone knew how to make something similier to this?
https://uk.youtube.com/watch?v=nIUck0dfnQ4
help if possible =) thanksDaniel Gauthier replied 17 years, 7 months ago 4 Members · 3 Replies -
Paul Hennell
January 31, 2009 at 11:06 amThat is a cool effect. No idea how they actually did it, but it clearly involves a good knowledge of particles.
If I was replicating the effect I’d probably use footage then take the end frame into photoshop separate the layers and mask them out as the particles come in. Still needs a good particle knowledge (Or appropriate plug-in) to make them properly explode.
Only in after effects do children get to pick and whip their parents.
https://hennell-online.co.uk -
Mike Park
February 3, 2009 at 2:21 pmIf I were doing this effect, I would shoot a clean bg plate and then cut out each element. Next, I would reassemble them inside a 3d program like 3d max and use 3d particles for accurate shadowing. I think you will not get as realistic a result inside AFX, even with particle plugins like Particular. This effect has been done many times before in 3d max. Finally, I would import the 3d particles into AFX and animate the reflections on the floor to correspond to the disintegration of the elements.
Hope that helps
Daniel Gauthier
February 3, 2009 at 9:11 pmOne way to recreate this effect without getting into a 3D application like Maya, would be to use Trapcode’s FORM plugin for After Effects. search the creativecow tutorials for more information on form. Depending on how much control you want over the look of the final render, you would probably have to separate each of the elements into different layers, and create displacement maps (or use the plugin’s physics parameters) for how you want the particles to dissipate.
https://www.trapcode.com/products_form.html
