Activity Forums VEGAS Pro Maybe the most basic problem for a project. Restoring windows.
  • Maybe the most basic problem for a project. Restoring windows.
    Posted by Jack Colvin on January 8, 2010 at 11:42 pm
    Hey guys,
    well recently i’ve been asked to make a video for someone, and i’m almost done, but as basic and novice as it seems i’ve managed to move the ” edit generated text media ” off the page, no problem like this has ever occured before so i haven’t the slightest clue how to centre it again. I’m sure people know, and help would be really appreciated.
    All the best, Jack.
    Jack Colvin replied 16 years, 6 months ago 4 Members · 5 Replies
  • Mike Kujbida
    January 9, 2010 at 12:49 am
    Odds are that it’s hiding at the bottom of the page.
    Try hiding your task bar to see if it shows up.
    If that doesn’t work, temporarily set your screen resolution to the next higher setting and it should become visible.
    Either way, once you find it, dock it again, change things back the way they were and you’ll be back in business 🙂
  • Terry Esslinger
    January 9, 2010 at 1:00 am
    If Mikes suggestions don’t work (and they should) you can reset the setup to factory defaults by rebooting Vegas with the Ctrl and shift keys depressed. HOWEVER any personalized settings will be lost.
    (wondering) Why did you post this twice?
  • John Rofrano
    January 9, 2010 at 1:52 pm
    You could also use View | Window Layouts | Default Layout to put all of the windows back in their place.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jack Colvin
    January 10, 2010 at 12:02 am
    Sorry, never knew you’d posted, although i’ll try this now , and thanks. I’ll get back to you if i’m still having problems.
    All the best, Jack.
  • Jack Colvin
    January 10, 2010 at 12:07 am
    Ah i’ve got it back, thanks a bumch for your help! I really do appreciate it and all the people who took their time to help me out.
    Jack
