Activity › Forums › Maxon Cinema 4D › Maybe it’s just my way of working…
  • Maybe it’s just my way of working…
    Posted by U. Bürgler on January 5, 2007 at 12:01 pm
    Hello
    I modeling some models for an Flight Sim Airport and have the folloing problem:
    When i aligned the textures onto the models i used the “flat” projection method, because it was easier for me that way.
    Now i want to use the connect function on the buildings, so that in the end i only have one objec per building. But as soon as i choose the Connect function, all texturealignments are totaly wrong.
    Here a link to an example how i textured the object, for better understanding: https://www.drinkz.ch/fs/problem.jpg
    Is there a way to ‘rescue’ me from doing the whole texture aligning again an the connected models or should i have used the UVW Tool from the beginning on?
    Thanks for Your help
    Ulrich
    U. Bürgler replied 19 years, 8 months ago 2 Members · 2 Replies
  • Lennart Wåhlin
    January 5, 2007 at 4:24 pm
    Try the ConnectScript by GeeSpot. Iit works in most cases better than the inbuilt command.
    It is to be found at his blog:
    https://iangorse.co.uk/blogs/index.php
    with instructions howto.
    As long as each object have a singel texture tag it is perfect. If you objects have more than one material (using selection ei) you might
    try to Bake Object (Under Render options). That will also create a singel object, but with a new single material.
    Cheers
    Lennart
  • U. Bürgler
    January 6, 2007 at 2:53 pm
    Hello Lennart
    Thank a bunch for that tip! It was excactly what i needed.
    Now i can finish the model as i planed. 🙂
    Thanks again
    Ulrich
