Activity › Forums › Adobe After Effects › Maxxon Lite Error
  • Maxxon Lite Error
    Posted by Patrick Morrow on November 6, 2013 at 10:28 pm
    I am just tapping into Maxxon 4D Lite and I save to see it in AE, I get this error always, please help!
    Patrick Morrow
    The error says:
    layer size must match composition and use default transform values
    Marcial Reiley replied 11 years, 6 months ago 3 Members · 2 Replies
  • Todd Kopriva
    November 6, 2013 at 11:14 pm
    It means what it says.
    When you create a layer based on a .c4d footage item, that layer must be the composition size. If you want to modify and animate things in the .c4d scene, then you use the controls in the Cineware effect and you use Edit Original to open the .c4d scene in Cinema 4D.
    Don’t just jump into trying to use this without going through the basic learning materials first:
    https://blogs.adobe.com/aftereffects/2013/04/details-of-cinema-4d-integration-with-after-effects.html
    After Effects team blog
  • Marcial Reiley
    March 15, 2015 at 4:30 pm
    In Cinema 4D Light, make sure your render settings are 800×600 or less and aspect ratio matches AE project (16:9, 4:3). No error messages after I checked these and AE camera works now.
    Videos for Good People and Good Causes
