Activity Forums Maxon Cinema 4D Maxon MoGraph Animation
  • Maxon MoGraph Animation
    Posted by Alejandro Torres on May 18, 2007 at 5:00 pm
    Hi everyone, I wnated to recreate this maxon animation: https://www.maxon.net/pages/products/modules/mograph/mov_effectors_1.html
    I’ve been experimenting with a step effector with a straight curve (clones grow constant) and with a height and size variation. I use the text I want to display as the fallof object. It works partially but the text can’t be read clearly (as in Maxon’s animation), it screws up the borders and he holes (the O hole) of the text.
    Any ideas or alternative methods? maybe just a little parameter tweaking?
    Regards
    Alejandro
    Mdme_sadie replied 19 years, 3 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    May 18, 2007 at 5:49 pm
    I think what they probably did was use two cloners: one for the wall of clones and another one for the word animation. I think they must have used a shader effector with the visibility parameter checked to create the word effect, along with another effector for the movement/scale.
    The problem with object falloff is that it only works with the falloff object’s vertices, so as soon as it passes through, you lose the falloff.
  • Mdme_sadie
    June 10, 2007 at 3:36 am
    It’s simpy a shader effector on a single cloner. The text is a movie.
