Activity Forums Maxon Cinema 4D Maximum render resolution?
  • Maximum render resolution?
    Posted by Max Stein on December 7, 2012 at 4:59 am
    Hello!
    I don’t gave C4D yet. I have a project to produce a single frame, not anamated image that needs to be rendered @ 300 dpi 3×5 feet to be printed. So that’s 10,800 x 18,000. Just would like to know how high of a resolution can be set? This would not be a big raytrace project. Just need the modeling ability. Alternately, what is the mac render resolution in Max3D?
    Thanks!!!
    Max
    Max Stein replied 13 years, 9 months ago 2 Members · 2 Replies
  • Darby Edelen
    December 7, 2012 at 5:31 am
    Cinema 4D has a render resolution limit of 128000×128000 pixels. However, several image formats don’t support resolutions this large. Most should support up to the resolution you’ve quoted here.
    There is also a method for setting up tiled renders to get around the 128000×128000 limitation in case you ever need it 😉
    Darby Edelen
  • Max Stein
    December 7, 2012 at 5:49 am
    Thank you. I can tile it as well, but it seems well within the render resolution.!
