Activity Forums Apple Final Cut Pro Legacy Maximum quality Youtube video
  • Maximum quality Youtube video
    Posted by Andy Gunn on March 26, 2010 at 3:51 pm
    Hi there,
    I’m new to FCP and have just made an 8min video of my band.
    It’s in 4:3 DV PAL format. I’d like to export it at the maximum quality for youtube.
    So, I exported it using quicktime conversion to MPEG4, video 200,000 bps, audio 320kbs, keeping the original screen size.. and this file plays fine on my computer and looks / sounds great.
    However, when I try to upload it to youtube I always get an error message, saying it failed.
    The file is about 1.3GB, so is within the 2G limit.
    What do you think might be wrong? I’m currently trying lower bitrate sizes but FCP takes ages to process it so can’t say yet if it’s this yet.
    Any ideas?
    Cheers
    Andy
    https://www.myspace.com/andygunnmusic
    Adam Keyes replied 16 years, 6 months ago 3 Members · 2 Replies
  • Stephen Smith
    March 26, 2010 at 8:53 pm
    I’ve had great luck with the H.264 codec. I use compressor to compress it. I set the quality high to around 10,000 or so. It looks great.
    Utah Video Productions
    Check out my Motion Tutorials
  • Adam Keyes
    March 29, 2010 at 1:33 pm
    Andy,
    Export settings are definitely tricky, and trial and error will always help you get a better understanding of how it all works.
    But I would think that you’re settings are way too high. You don’t need a 1+ gig file if you’re final video is 8 minutes long, in SD format.
    Try this:
    Export using QT convers
    quality: high
    keyframes: auto / or 30 / or 24 for PAL i guess
    audio: probably just leave it, or you can change to aac and leave the rate, or go to 96, 128, etc
    try that, see how it looks/sounds, and then adjust things accordingly. that format should upload to youtube great. the keyframes will adjust the filesize a lot, but i export things at 60 or 120 keyframes and they can still look good.
    set your in and out points in a 20 second section of your video, then start exporting and keeping track of what settings you used, then you can compare them all to each other, then you should know what looks good for you!
    Cheers,
    Adam Keyes
