Activity Forums Adobe Premiere Pro Maximum project length in Premiere Pro 1.5?
  • Maximum project length in Premiere Pro 1.5?
    Posted by Jim Leonard on September 4, 2006 at 5:45 pm
    I tried to export a 3h18m project in Premiere Pro 1.5 (not imported from an earlier version, but completely created in PPro) and at some point (don’t know when as I left it to render overnight) it errored out with “I/O error”. From past experience, I remember that “I/O error” in Premiere can mean a ton of things not actually associated with disk I/O; besides, I’ve tested the disk and it’s fine.
    Is the project length in Premiere Pro 1.5 limited to 3 hours, or could something else be going on?
    (PS: I tried searching adobe’s support to no avail)
    Andrea Di varmo replied 20 years ago 4 Members · 4 Replies
  • Aanarav Sareen
    September 4, 2006 at 8:07 pm
    A couple of questions:
    a) What format are you exporting as? AVI? MPEG?
    b) How much disk-space is available on your export drive?
    c) How much disk-space is available on your C:\ drive?
    d) How much disk-space is available on your scratch disks?
    Try defragmenting your drive to see if it solves the issue.
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Jim Leonard
    September 4, 2006 at 10:00 pm
    It’s none of that, but I’ll answer anyway to satisfy your curiousity:
    – Exporting as AVI (uncompressed, using Blackmagic Design 8-bit YUV 4:2:2 codec — yes, it is huge)
    – 300GB available on export drive
    – Obviously not that much available on C:\ but that never is touched during the export
    – Scratch is set to the same as the export drive
    There is plenty of space available — I’m just wondering if Premiere Pro 1.5 has some sort of goofy limit I wasn’t aware of.
    Update: I’m getting around the problem by rendering to smaller chunks and then stringing them together using avisynth, since all I need to do at this point is feed the final project to the MPEG-2 encoder I’m using… still, if there is a real cause, I’d like to know it…
  • Steven L. gotz
    September 5, 2006 at 12:09 am
    The timeline in Premiere Pro is 24 hours maximum. So that isn’t the problem. It is more likely a problem with the Blackmagic drivers interaction with Premiere Pro. I have no clue which of the 2 is the real problem.
    Steven
    https://www.stevengotz.com
  • Andrea Di varmo
    September 6, 2006 at 10:07 am
    Are the disk in Fat32 or Ntfs?
