Activity Forums Compression Techniques maximum program length for DL dvds
  • maximum program length for DL dvds
    Posted by Wayne Kurtz on January 12, 2010 at 8:20 pm
    To preserve picture quality, I use the 6.2 mbps (90 minute setting) in Apple compressor v 3.5.1.
    When i drop in a 90 minute SD NTSC QT movie, with chapter markers, this 6.2 setting compresses a file which ultimately just fits on the entire dvd 4.7 gb disk.
    I now have a 2.5 hour (150 min) program which I would like to burn onto 1 Dual Layer disk. Will the same 6.2 bit rate compress the file so that it will fit onto the 8.5 gb DL dvd?
    Is there a reliable bit rate calculator for Apple compressor?
    wayne
    Daniel Low replied 16 years, 8 months ago 2 Members · 1 Reply
  • Daniel Low
    January 12, 2010 at 8:25 pm
    So, you’re not doubling the amount of content by you have twice the space available.
    You must be able to answer the question from that!
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today: 30 April 2007
