Activity › Forums › Adobe Encore DVD › Maximum movie length for good quality
  • Maximum movie length for good quality
    Posted by Rex Summerfield on March 21, 2009 at 5:07 pm
    Hi All, I was wondering what you have found is the maximum length of a DV AVI movie you can “reliably” compress and put on a single layer DVD without getting motion artifacts and other trash. Hour and a half? More? Less?
    Jeff Bellune replied 17 years, 6 months ago 2 Members · 3 Replies
  • Jeff Bellune
    March 21, 2009 at 6:52 pm
    90 minutes give or take a few. It depends on the footage. High-motion footage or footage with a lot of detail like forests and water surfaces will need higher bit rates which will limit the time available. You could get up to 2 hours for stuff like talking heads.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Rex Summerfield
    March 21, 2009 at 8:37 pm
    Thanks Jeff, Do you find that Encore does a good job with auto compression for movies pushing the 90 minute mark or do you figure the bit rate and set it manually?
  • Jeff Bellune
    March 21, 2009 at 8:46 pm
    I’ve been happy with Encore’s performance when Automatic Transcoding is used for projects 90 minutes or less.
    -Jeff
