Activity Forums Adobe After Effects Maximizing Output for DVD
  • Maximizing Output for DVD
    Posted by Whitlock Dunbar on August 31, 2007 at 11:31 pm
    I was torn between posting this here or in the Encore forum but since I know AE better, here ’tis.
    I like to think I know AE pretty well but I’m stumped on this one. I built a composition (D1 Widescreen Square Pixel preset) comprised of webpage comps built in Photshop (1920 x 1080) and text generated in AE. After some pushes and transitions were added I rendered out a .mov file (Animation codec, best quality). The client wanted this authored as a single play DVD.
    Here’s where I need help. I tried creating a DVD with Nero, Toast and Encore CS3, but in every case the quality of the DVD was MUCH worse than my .mov file (illegible text, blooming reds, aliasing, etc.). Now I know there are a million variations within the settings of these programs (believe me, I’ve been tweaking for days now) but because all three authoring applications produced similar poor results I wonder if I’m missing something simple.
    Is there a preferred set of settings for output from AE to create DVD? Or better can someone direct me to a website that deals with authoring DVDs in a professional environment (all I have found are aimed at consumers). Thanks all!
    Whitlock Dunbar replied 19 years ago 3 Members · 3 Replies
  • Brendan Coots
    September 1, 2007 at 12:49 am
    Rendering out to the Animation codec from AE is fine, however you said your comp is widescreen square pixel aspect ratio, and HD size. I don’t personally use Encore, but most video apps are expecting standard 0.9 pixel aspect ratio. Also, the DVD spec (which is mandatory) absolutely requires 720×480 video UNLESS you have an HD-DVD burner. so maybe Encore is freaking out on the square pixel file (shouldn’t be a problem as I use them in DVD Studio Pro), or the fact that the file is a huge HD file it doesn’t know how to handle, so it just squeezes and compresses it to death.
    You should try nesting your comp in a standard NTSC DV Widescreen 0.9 aspect ratio comp (again, DVD spec calls for 720×480 files) and output that, then feed the resulting file into Encore.
    Also, all the various settings for DVD output via Encore (or any other decent DVD authoring app) don’t need to be tweaked really. They are mostly there for control when your source material is longer than will fit on a standard DVD.
    That said, I would get your settings back to some default (I don’t use Encore so I’m not sure how you would do this) and then only adjust one setting – the bitrate. This should almost always be around 6Mbps average, with a max bitrate of around 7Mbps. If it is an option (again I don’t use Encore) use 2 pass Variable Bit Rate. This will give good quality and will ensure the file isn’t too bitrate heavy, which will cause some DVD players to skip and freak out.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Erik Pontius
    September 1, 2007 at 3:23 pm
    I re-read his original post. I think he created a sq pixel widescreen comp, and not an HD comp, he’s just using screenshots created in PS that are 1920×1080.
    Keep in mind that the lower resolution and interlacing of DVD is not friendly to graphics and other material with fine detail (like text on a webpage). Keep this in mind when you build your comps in AE, since you are working with large graphics, you can pan/zoom into areas to make them larger. Another trick for stills that have a lot of fine detail is to add a small amount of vertical blur, 1 pixel should do it. You might also consider generating fields in your render settings in AE (i.e. lower field first).
    Last but not least, I’m sure that the built in mpeg encoder in encore is adequate for some quick jobs, but most of your pro’s are going to be using stand-alone encoders (like Canopus Pro-coder, Sorenson Squeeze, etc…) where they can control the encode to get the best quality, calculating out bitrates to squeeze the highest bitrate keeping within the space limitations of the disc. I wouldn’t go higher than around 7mb/s unless you plan on getting this disc replicated at a facility and your delivery to them is DLT tape.
    Erik
  • Whitlock Dunbar
    September 3, 2007 at 1:35 am
    Thanks guys! Between your two posts I see a lot that I have either overthought or done incorrectly.
    Yes this is a wide-screen, not HD presentation so I’ll nest the master into a new comp. Also I’ll do the vertical blur trick and set the output to lower field.
    I have Squeeze 4, and I’m suprised to learn that it is the better choice over Encore for creating a DVD (in terms of quality). I’ll be returning to this project mid-week so I’ll post the outcome.
