Activity Forums Apple Motion Max resolution w/ 1900xt & 7300gt
  • Max resolution w/ 1900xt & 7300gt
    Posted by Toke on March 23, 2008 at 1:33 pm
    I have 1900xt & 7300gt installed in older mac pro.
    If I attach monitors to both adapters Motion reports 2364×2364 as max resolution.
    If I unplug monitors from 7300gt, I’ll get 4096×4096 for max rez.
    Any workarounds for not having to unplug monitors each time I want to use Motion?
    Toke replied 18 years, 5 months ago 2 Members · 2 Replies
  • Gabriele De simone
    March 26, 2008 at 9:10 pm
    I think Motion takes in consideration the graphics card that is connected to the main display. The main display is the one where the menubar appears. You can set the main display via the System Preferences. Have you tried making sure that the main display is connected to the X1900?
    Hope this helps,
    Gabe
    Noise Industries, LLC
  • Toke
    April 4, 2008 at 1:07 pm
    Conf1:
    1900xtPort1:1920x1200dvi
    1900xtPort2:1600x1200vga(menubar)
    7300gt: no monitors
    MotionMaxRez: 4096×4096
    Conf2:
    1900xtPort1:1920x1200dvi(menubar)
    7300gt: no monitors
    Conf3:
    1900xtPort2:no
    7300gt: no monitors
    Conf4:
    1900xtPort2:no
    7300gtPort1:1600x1200vga
    Conf5:
    MotionMaxRez: 3344×3344
    Conf6:
    Conf6:
    Conf7:
    1900xtPort2:no
    7300gtPort1:1600x1200vga(menubar)
    7300gtPort2:1600x1200vga
    MotionMaxRez: 2364×2364
    Conf8:
    1900xtPort2:no
    7300gtPort2:1600x1200vga(menubar)
    Conf9:
    1900xtPort2:no
    Conclusion: primary screen does affect maxRez, but not alone.
    You can’t use 7300gt at all, if you want to have 1900xt’s maxRez…
