Activity › Forums › Apple Final Cut Pro Legacy › Max resolution for tif in FCP?
Posted by Brad Bussé on August 28, 2009 at 10:41 pmWhat is the max vertical resolution for a .tif importing into FCP? I tried importing a tif 38k pixels tall but it wouldn’t come in – I cut it in half vertically and that came in okay.
Brad Bussé replied 17 years, 1 month ago 4 Members · 7 Replies -
Shane Ross
August 28, 2009 at 10:56 pm38k? or 38K? 38,000 pixels? FCP has a limit of 4000×4000…4K.
Shane
Read my blog, Little Frog in High Def -
Brad Bussé
August 28, 2009 at 11:13 pm38,000 pixels. I was able to cut the file down to 1280×20,000 and that imports okay. The sequence is only 720p.
Shane Ross
August 28, 2009 at 11:23 pmWell, I’ve always had issues with stills over 4000K. FAILED TO RENDER errors.
Shane
Brad Bussé
August 28, 2009 at 11:46 pmMaybe it’s something that’s been changed in FCP 7, I don’t know – normally I’m working with smaller files. I haven’t exported, but I animated it and it renders in the timeline fine. The only problem I have now is that there’s a maximum value on the position transformation of 10,000 pixels in any direction, so I need to split more evenly, or split into thirds. If it doesn’t export I’ll probably just re-author in AE rather than splitting it into ~15 pieces. Thanks.
Nick Meyers
August 29, 2009 at 6:30 amthe 4000 pixel limitation in FCP is (was?) in relation to SEQUENCES.
you cant create a sequence with a frame size larger than 4000 pixels.
there is no hard, coded-in frame-size limit on images you import.
i have had rollers that have gone way over 4000 pixels high,
and not had problems.oh, and here’s a curio:
if you import a layered PSD file larger than 4000pixels,
it will come in as a sequence LARGER than 4000.
so that is a way to get around FCP’s limit.
seems like asking for trouble to me, though.nick
Gary Adcock
August 29, 2009 at 2:01 pm[Nick Meyers] “the 4000 pixel limitation in FCP is (was?) in relation to SEQUENCES. you cant create a sequence with a frame size larger than 4000 pixels.
there is no hard, coded-in frame-size limit on images you import. “Actually there are some guidelines Nick.
Yes – The pixel limitation in Final Cut is for the sequence width settings only and it is hard coded in the sequence settings – the vertical pixel limitation for such a file is with photoshop. I have loaded 2048 x 20,4800 pixels images in for a credit roll in FCP 6
however there is a point where the processing of files with larger vertical pixel aspects are limited by the computer’s CPU / RAM config- the beefier the machine the bigger you can go.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, ILhttps://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Brad Bussé
August 30, 2009 at 3:55 amLooks like the limit on my system is somewhere between 32,000 and 33,000 pixels; 3.2 octacore w/ 16 GB RAM.
