Activity Forums Adobe After Effects Max RAM usage
  • Max RAM usage
    Posted by Shaun Au on March 19, 2009 at 5:39 pm
    Guys,
    My previewing time and rending time is slow in AE. I have 18GB of physical RAM installed on my Mac Pro 8core 2.8 system. But in the AE Memory and Cache it only has Max RAM usage set to 3GB(100%). Why is this so? Shouldn’t 100% equal to the amount of physical ram I installed(18GB)?
    Please help. Thanks.
    Shaun
    Kevin Camp replied 17 years, 6 months ago 2 Members · 1 Reply
  • Kevin Camp
    March 19, 2009 at 6:46 pm
    all versions of ae are 32-bit, as a 32-bit application the most ram that they can use is 4gb (3gb of a foreground application in osx).
    to get around the 32-bit limitations, you can enable multiprocessing in later versions of ae (in cs4: preferences>memory & multiprocessing; in cs3: preferences>multiprocessing). this will launch a render engine for each available core and each 32-bit render engine being able to grab up to nearly 4gb (about 3.5gb for osx) of ram.
    so if you have 8-cores, ae can effectively use nearly 32gb or ram, but the max ram usage will still say 3gb for the main application.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
