Activity Forums Apple OS X Max out eMac RAM
  • Max out eMac RAM
    Posted by Bruce Himmelblau on February 15, 2008 at 12:48 am
    I have a 1.25GHz eMac with a 512MB & a 256MB RAM chip. I’ve read that it max’s out at 1GB, which means that I can only replace the 256MB chip with a 512MB chip. I’ve found compatible 1GB chips. How much RAM can I put into the 2 slots to get the most out of it? I’m looking to use it with FCP 6 & DVD SP 4.
    Thanks.
    Bruce Himmelblau replied 18 years, 7 months ago 2 Members · 2 Replies
  • Jeff Carpenter
    February 15, 2008 at 4:27 am
    Looks like you have the 2004 eMac. Double check this page to make sure I got that right:
    https://www.apple-history.com/
    Just double-checking. But if so, all that confirms is that you’re correct. You can only use two 512 chips in that machine. Anything more will not be recognized by the system.
    Use the pull-down menu here to find your eMac:
    https://www.crucial.com/mac/index.aspx
    Looks like it should run you about $33.
  • Bruce Himmelblau
    February 15, 2008 at 7:24 pm
    It just may be time to get a new system. It’s been a good back-up unit for FCP 5. Except for the speed issue and the fact that it can’t run Motion and other Studio2 programs, it’s working fine.
