Activity › Forums › Adobe After Effects › Max number of image files is 32767…
  • Max number of image files is 32767…
    Posted by Richard Needham on December 1, 2006 at 7:20 pm
    My AE7 is limiting the import of frame sequences to 32767 frames, the old FAT32 directory maximum! These are TGA frames (~39,000) created with AE7. PPro2.0 opens them fine. AE7 will even truncate the sequence when opening the PPro project. A reinstall of AE7 changes nothing. After a full Production Studio reinstall it’s fine the first time running then it begins truncating. I installed AE6.5 and it truncated also.
    The one error message I’ve had read AE Error: getting number of files in directory — file not found 3::44
    The pref file is default, and should be good for more than 39,000 frames.
    R
    Mylenium replied 19 years, 10 months ago 3 Members · 2 Replies
  • Tobias Pfeiffer
    December 1, 2006 at 7:32 pm
    same here.
    i think that
  • Mylenium
    December 1, 2006 at 8:05 pm
    Yupp, using sequences longer than that exhausts the handling buffer in AE and indeed it has to do with the 32bit-ishness of many parts of AE (simple legacy issues, no obvious technical reason). Just split your sequence like Tobias said.
    Mylenium
    [Pour Myl
