Activity Forums Apple Final Cut Pro Legacy max clip size in HDV?
  • max clip size in HDV?
    Posted by Sherry Daniel on March 3, 2008 at 4:38 am
    Hello,
    I am editing a long-format documentary in FCP 6.0 with footage in HDV and DV. This is my first time working with the HDV format.
    Does anyone have any experience working with long clips in HDV? Is there any downside to loading 15 minutes, 30 minutes of footage in one clip? I’d like to load-in quickly, then organize subclips later.
    thanks for any advice.
    Tom Wolsky replied 18 years, 6 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    March 3, 2008 at 1:40 pm
    THere shouldn’t be any problems other than those presented by the HDV material itself.. HDV isn’t a very efficient codec, but long captures shouldn’t be a problem per se… Search this forum on the talk surrounding the GOP structure of HDV… There’s a lot of work arounds including capturing it as something OTHER than HDV. Like ProRes instead.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Tom Wolsky
    March 3, 2008 at 2:42 pm
    Depending on the exact format and devices you’re using FCP will most likely break each shot into a separate clip. You can do that on capture.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Sherry Daniel
    March 4, 2008 at 4:55 am
    yes, the automatic clips are very handy. But I notice that it isn’t happening for HDV footage shot on a different camera. So it looks like some manual logging will be necessary to keep those clip sizes manageable.
  • Tom Wolsky
    March 4, 2008 at 12:44 pm
    There is a setting for this in FCP to turn it on and off. It works with some devices, not with others.
    All the best,
    Tom
