Activity Forums Apple Final Cut Pro Legacy Max Clip Length?
  • Max Clip Length?
    Posted by Jason Levy on June 26, 2008 at 6:17 pm
    We received some audio that was recorded on a digital multi track recorder. The files are WAV format. It was an all day shoot and they just started the recorder in the morning and ran it continuously all day.
    Therefore the clips are around 8 hours long. When we try to import them into Final Cut the come in at around 4 hours – truncated.
    I guess we are running into some kind of limitation.. can’t seem to figure out if it’s the software, the filesystem or what…
    Any suggestions?
    Jason
    Jason Levy replied 18 years, 1 month ago 2 Members · 6 Replies
  • Jeremy Garchow
    June 26, 2008 at 8:23 pm
    Break it up in to smaller aif files? You can set ins and out in compressor.
    Jeremy
  • Jason Levy
    June 27, 2008 at 6:06 pm
    Tried that but they are truncated when imported into compressor; same problem..
    Thanks for trying!
    jason
  • Jeremy Garchow
    June 27, 2008 at 6:22 pm
    Can you open them in Quicktime?
  • Jason Levy
    June 27, 2008 at 6:44 pm
    Same problem.
    j.
  • Jeremy Garchow
    June 27, 2008 at 7:24 pm
    Are they BWaves or just plain ole wavs? Can you open them on a PC?
  • Jason Levy
    June 28, 2008 at 6:38 pm
    Good questions. I’ll find out.
    THanks for your help.
    j.
