Activity Forums Adobe Premiere Pro Max Bitdepth dropping luminance
  • Max Bitdepth dropping luminance
    Posted by Dan Powers on February 11, 2020 at 7:57 pm
    This is something I have not seen before.
    Putting a ProRes HQ clip on the timeline and it looks as it did when it came out of resolve. Change sequence settings to Maximum Bit Depth and now the clips are about 20 IRE darker! See image below. Right Image is Max BD. Left is unchecked.
    Strange. Also shows this result on Mercury Transmit outputs.
    New bug?
    Olivier Binette replied 6 years, 6 months ago 2 Members · 3 Replies
  • Dan Powers
    February 11, 2020 at 8:23 pm
    Just confirmed this is only happening in 2020 Premiere Pro 14.01 . And not happening in Premiere Pro 13.1.5
  • Olivier Binette
    February 17, 2020 at 3:34 pm
    Same for me here. The problem is not only for Premiere Pro it affects Media Encore too.
    I tested multiple codec in and out, and the problems stays the same.
    I found a workaround in Premiere Pro, you can work in a timeline without maximum bit depth option check in the timeline settings. Then you can export this timeline with Premiere Pro (not with Media Encoder) with the maximum bit depth check and the export should be normal.
    I work on a
    iMac (Retina 5K, 27-inch, Late 2015)
    Radeon RX 5700 XT 8 GB
    with a clean Catalina install
    This bug is really annoying! Most of my work must be 10 bit or more, Media Encoder 2020 is unusable for me right now.
    I’ll stay on Premere Pro 2019 and Media Encoder 2019 for now.
    Anybody reported this bug to Adobe yet?
  • Olivier Binette
    March 9, 2020 at 2:22 pm
    Updating to 14.0.3 solved the problem.
