Activity › Forums › Apple Final Cut Pro › Mavericks QT Player X “Converts” FCP X Quicktimes Before Playing
Keith Koby replied 12 years, 6 months ago 8 Members · 17 Replies
Keith Koby
February 12, 2014 at 1:18 pmMy bad. Ok – so after fcpx or qtx “conversion”, it plays nicely. It sounds like a qt atom type of thing that is not in the non-apple originating prores files.
And as you posted earlier, no problems with these files in fcpx, just outside.
Oliver Peters
February 12, 2014 at 1:23 pmActually the original file, without any conversion, plays fine in FCP X. Just a standard import (leave media in place). In my case, the original file is ProRes.
Oliver
Orlando, FL
http://www.oliverpeters.com -
Keith Koby
February 12, 2014 at 1:26 pmAgreed. No problems with these prores sources inside of fcpx, only outside.
Keith Koby
February 12, 2014 at 2:18 pmThanks Jari. From the kb, it looks as if ProRes files should playback in quicklook with no issue, but it is not the case with (at least some, maybe not all) third party created ProRes files.
Bret Williams
February 12, 2014 at 3:11 pmI have had a few files that wouldn’t play in QTX, but they were just fine in Legacy! Some of those include ProRes LT from an unknown client source.
Keith Koby
February 12, 2014 at 5:12 pmFor posterity, I’m doing a reset of the subject and re-defining the issue:
In Mavericks 10.9.1, attempting to play some 3rd party generated ProRes .mov files through either QuickLook (spacebar) or QT Player X, results in unexpected behavior:
1. On opening, QuickTime Player X will convert the ProRes file to the same format (ProRes) before playing it and prompt the user to save the new movie on close. According to this KB, QT Player X should play ProRes without convert. https://support.apple.com/kb/HT6055
2. QuickLook does not play the movie and instead displays a still and shows the file’s size as 0 kb.
Additional info:
The issue seems to only affect ProRes files that come from third-party transcoders (i.e. vantage) or third-party cameras that record to ProRes.
The preview picture in the finder for assets that experience this problem is a 4:3 image with letterbox when the actual asset is 1080 HD 16:9. CLAP atom issue?
