Activity › Forums › Adobe Media Encoder › Mavericks & Lossless Exports
Posted by Emily Dekovich on January 23, 2014 at 7:52 pmMavericks isn’t playing nice with Animation or PNG codecs (See https://support.apple.com/kb/HT6055 )
So, I am looking into how to export a lossless H.264 file from AME. I’ve heard there is a way of doing this, but am unclear on how to ensure it is lossless, as H.264 is one of the few lossless codecs QT 10 will now play without automatically converting.
I’m aware QT 7 will work, but am just curious of a workaround for QT 10.
Thanks!Emily Dekovich replied 12 years, 8 months ago 3 Members · 8 Replies -
Todd Kopriva
January 24, 2014 at 12:40 amI would be very surprised to learn that any H.264 compression result could possibly be lossless.
What is the purpose of these files? Are you using them as intermediates in a post-production pipeline?
After Effects team blog
Jeff Pulera
January 24, 2014 at 7:01 pmHi Emily,
What about ProRes with alpha?
Jeff Pulera
Safe Harbor Computers -
Todd Kopriva
January 24, 2014 at 7:10 pmProRes 4444 (which Jeff is referring to) is lossy, but it loses _very_ little information in one or two generations of compression. I use it as an intermediate codec when doing compositing work for webisodes, and I don’t find any crucial information to be lost.
Emily Dekovich
January 24, 2014 at 8:37 pmThat is what I was thinking as well, I heard about a lossless H264 format from other online forums but have never encountered it in my own work. My only hesitation about ProRes 444 is that Windows won’t play it.
The purpose of this output is to give a client a highest resolution copy as possible for archiving purposes. That way if they need the video in another format they can compress it easily on their end. -
Emily Dekovich
January 24, 2014 at 8:38 pmMy assumption is that Windows will not play this format unless the user has downloaded an additional plugin for QT, but i may be wrong.
Jeff Pulera
January 24, 2014 at 8:43 pmHi Emily,
While I’ve not specifically tried ProRes 4444 on a PC, the regular ProRes files work fine on PCs as long as the standard QT player is installed, no special plug-in needed.
Jeff Pulera
Todd Kopriva
January 24, 2014 at 9:43 pm> My only hesitation about ProRes 444 is that Windows won’t play it.
That is not correct. QuickTime on Windows can play any of the ProRes flavors. It’s encoding (writing, creating) ProRes files on Windows that is the problem.
