Activity › Forums › Boris FX › Mattes in Red
  • Mattes in Red
    Posted by Ian Johnson on September 26, 2008 at 10:24 pm
    I am just beginning to learn Red, and getting a little hung up on mattes.
    If I want to matte a layer, I can add a still image track into the mask of the face. So far I can only get a matte to happen if the image I drop in has an alpha, and the alpha is used rather than the RGB value of the image.
    If I have a B&W image or an animated B&W video or composite that I want to use as a mask, how do I make that work?
    Ian
    Peter Mcauley replied 18 years ago 3 Members · 3 Replies
  • Steve Pankow
    September 28, 2008 at 1:11 am
    I’m not in front of a system, but wouldn’t you just apply a Chroma or Luma key to the image inside the mask track?
  • Ian Johnson
    September 28, 2008 at 3:11 am
    I suppose that might work for things that need to be cut out cleanly, but not so much for a range of transparency.
  • Peter Mcauley
    September 29, 2008 at 1:48 pm
    To achieve this effect, do the following:
    • Add the PixelChooser filter to the mask track ot the clip to which you wnat to add alpha
    • The PixelChooser output should be set to Alpha Channel
    • Twirl down the PixelChooser track so that you can see the PC Layer sub-track
    • Add the media that you wish to use as alpha to the PC Layer
    • Click on the PixelChooser track to access the parameters i the controls panel
    • Click on the Matte tab
    • Enable the Use PC Layer Track button – you should now have a track matte
    Cheers,
    Peter.
