Activity Forums Adobe After Effects matte to mask
  • Kevin Camp
    October 11, 2007 at 1:26 pm
    layer>auto trace… can create a mask from an alpha channel. it can take a while based on settings, but it is effective.
    a quicker way you may be able to use would be to duplicate the keyed head, then use it as a track matte for a solid that is the color you want for the outline. then apply simple choke to the track matte to grow it out a bit…
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Mike Clasby
    October 11, 2007 at 5:11 pm
    For a walk-thru, Aharon has a 3 minute video tut that uses a similar method, here:
    https://forums.creativecow.net/articles/rabinowitz_aharon/outline/index.htm
  • Kevin Camp
    October 11, 2007 at 7:44 pm
    that aharon’s good… that shaves a step or two off my method…
    Kevin Camp
  • Lumpynifkin
    October 11, 2007 at 9:46 pm
    In keylight if you simple use the screen matte and set the replace color to the color you want, set replace method to hard colour. You can then use screen Shrink/Grow to determine the size of the stroke. This just takes a few steps off of arron’s method.
