Matte Showing on RPF Sequence
I’m having a problem with a sequence that is being exported from 3ds Max. The edge is showing a matte.
I am exporting from Max as a 16bit RPF sequence with straight alpha (NOT premultiplied). I’m getting a matte around the image.
I have found that applying a “Alpha Levels” effect in AE7 does clean up the edge very nicely. However, I would like to find the best method for importing with the cleanest edges.
I created a graphic that shows the problem I am having.
https://www.timhull.com/out/Hendrick-16bit-Straight-Alp.jpg
I would greatly appreciate any help with this!
Tim
Tim Hull
