Activity Forums Adobe Premiere Pro Matte Question
  • Matte Question
    Posted by Mikke1556 on December 27, 2006 at 11:35 pm
    Hey, this question is probably really easy but anyways..
    i created this comic strip layout in photoshop, saved as a psd and imported it to premiere pro. there is no backround in the layout, just red boxes. What i want to do is put seperate videos in the all the boxes. What is the easiest way to achieve this?
    Mr_red replied 19 years, 7 months ago 3 Members · 2 Replies
  • Keithallison
    January 29, 2007 at 10:27 pm
    probably the easiest way of doing this would be to import your movie files onto separate layers… in the monitor window, simply click the video clip and resize it to fit your red box. Do this with each clip and you should be set. This is like I said, the easiest way of doing it… as with anything, there is more than one way to do it…
  • Mr_red
    February 12, 2007 at 4:50 pm
    I haven’t got to grips with a matte – can I (say) use it to block-off half the scene with a chroma colour which would be used for keying.
    two of these (top and bottom) could then be used on two identical clips to move the clip apart and reveal a bottom layer holding a “second” clip. The motion would be customised.
    Can a “blue screen” matte be sized and overlaid to effectivly create an alpha channel.
    The only other way I see is creating two clips separately with a chroma fill on each and while they remain in their normal position they result in a seamless join (doubtful) until each move. The upshot then is the end clip is third generation, not to mention the storage they would need.
    Slinks away to look at the help file…………… (Assuming it is understood)
