Activity › Forums › Adobe After Effects › matte pass problem
  • matte pass problem
    Posted by Accountclosedduetonorealnameused on July 7, 2006 at 2:21 pm
    I have a RGB pass and a matte pass from a 3D app.
    The matte pass has different colors for different 3D objects rendered in the scene.
    Problem is I want to use the Set Matte filter on the RGB pass to isolate different parts of the picture I want to show, but the set matte does not have specific color options, only Red, Green, Blue color channels, but my matte has other colors as well as RGB. I wish there was a way to use set matte to pick an exact color. Is there?
    thanks!
  • Mylenium
    July 7, 2006 at 2:24 pm
    Use the Shift Channel and Set Channel effects to extract your RGB mattes.
    Mylenium
    [Pour Myl
  • Accountclosedduetonorealnameused
    July 7, 2006 at 2:48 pm
    but, the matte is not strictly RGB, there I think it is CMYK or some other colors.
  • Mylenium
    July 7, 2006 at 3:36 pm
    Yeah, and what would be the problem with that? You can still isolate the mixed colors easily by cutting them with the pure color mattes. E.g. if you have a magenta matte and a red one, you can extract the red in both of them and cut away the unneeded red parts of the magenta with a blue matte. This is really simple. All you may need eventually is to adjust the levels to avoid semi-transparent areas in some cases.
    Mylenium
    [Pour Myl
    July 10, 2006 at 6:24 pm
    this worked great, thank you!
