Activity Forums Adobe After Effects Matte line is cropped – easy fix?
  • Matte line is cropped – easy fix?
    Posted by Brad Nelson on August 15, 2009 at 1:38 am
    Hello,
    I am a student and pretty new to After Effects. I created a matte around an object I am keying but for some reason the top inside part of the matte seems to be cropped of the ability to make changes.
    Here is a link to a screen shot to better illustrate my problem.
    https://www.hotlinkfiles.com/files/2745498_8yjjx/matteproblem.tiff%5Dmatteproblem.tiff
    I’ve tried adjusting the matte position and size but the top area remains constant. It seems like I’m missing some silly little thing here, any help would be greatly appreciated.
    Brad
    Andy George replied 17 years ago 2 Members · 2 Replies
  • Brad Nelson
    August 15, 2009 at 4:32 pm
    oh and by matte, I mean mask.
  • Andy George
    August 15, 2009 at 8:14 pm
    Hi Brad,
    Your mask is extending beyond the edge of your adjustment layer. The adjustment layer
    is basically a comp sized solid.
    With the adjustment layer selected go to Layer>solid settings. you can
    increase the size of the solid here.
    Rather than animating the adjustment layer you might have better luck animating the mask.
    If you twirl open the mask properties you can see the mask path property. This is where
    you can animate the shape and position of the mask.
    -Andy
