Activity Forums Adobe After Effects matte color vs keycolor
  • matte color vs keycolor
    Posted by Dotan Baytman on August 13, 2005 at 11:46 am
    HI everyone
    i have a two files of an explosion one is the video itself on a black background the second is the matte video
    so my question is when/why to use the matte video and not just use the keycolor or any other keying to take the black of the video and then make it a video with alpha?
    both technics work for me
    so what is the most use of the matte videos?
    thanx in advance
    Chris Smith replied 21 years, 1 month ago 2 Members · 3 Replies
  • Chris Smith
    August 13, 2005 at 3:30 pm
    Well, if nothing else, the matte has already been done for you. We assume that the edges of the matte were optimum since they come with a pro library. Keying on black still will grab black parts of the explosion and not probably not give you as clean of edges since you are basically keying on a luminance value because black has no color. Color keys which separate themselves by saturation, hue, and luminance have more defined edges than luminance keys.
    But with stuff shot on black, you can use the free plug-in ‘unmult’.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Dotan Baytman
    August 13, 2005 at 4:57 pm
    HI chris
    thanx for the reply
    two questions for you
    first what is the best way to use the matte? i use the chanell matte if thats its name i dont remember its in the chanells plugins
    or is there a better way?
    second where can i get this plugin u mentioned? or i can just use one of the keying plugins?
    thanx in advance
  • Chris Smith
    August 14, 2005 at 6:16 am
    1. If you have the explosion on one layer, import the matte on a second layer. Put the second layer right above the explosion. Then on the explosion layer, set it’s track matte to luma matte. That way it will use the luminance from the layer above it (your explosion matte) as it’s own matte channel so it’ll cut out the way it is intended.
    2. Knoll Unmult is here:
    https://www.redgiantsoftware.com/unmult.html
    Chris Smith
