Activity Forums Adobe After Effects Matrox Software Codecs -> CRASH AE
  • Matrox Software Codecs -> CRASH AE
    Posted by Chris Tabor on September 9, 2009 at 9:03 pm
    Hello,
    I am hoping someone can help with this maddening problem 🙂
    I capture a clip (no audio) with a Matrox Digisuite LE on PC#1. I then take that clip on ANY other PC running AE CS4 with the Matrox Software Codecs installed). Clip imports correctly and all is ok, until I do a RAM preview or Render that clip. AE totally crashes (no save). No effects on timeline. No audio. Here is the kicker… Close AE, go back to PC#1 and simply ‘re-capture’ that same clip. Open the AE project back up and voila! problem fixed! To make the troubleshooting worse, this doesn’t happen on all clips. 80% of the clips are fine from the beginning. To further complicate matters, I can take that same “Corrupt” clip into AE CS3 and it works there. Not in CS4 though.
    Info that might help:
    -All clips are copied onto a local drive.
    -All pc’s are windows XP, 32bit and 64bit (no difference)
    -Field interpretation makes no difference…
    -Memory Cache makes no difference
    -Completely different PC has no effect
    -Calling MATROX makes no difference, lol
    -Calling Adobe makes no difference
    Thanks for the help!
    Jason Byfield replied 16 years, 5 months ago 2 Members · 3 Replies
  • Chris Tabor
    September 9, 2009 at 9:43 pm
    Thanks for the speedy reply!
    Both work-a-rounds work fine but so does just re-capturing the clip. I’m need to find a fix or where the problem is to begin with. I’d say there is something wrong with the clip and how it was captured, but then it works fine in CS3.
  • Chris Tabor
    February 19, 2010 at 2:34 pm
    Anyone have any thoughts?
  • Jason Byfield
    April 23, 2010 at 5:07 pm
    It could possibly be related to this post:
    https://forum.matrox.com/mxo/viewtopic.php?p=10821&sid=cb742f0b5fe523433ac33fcf655e0936
    I was having a huge stability and RAM preview problem with AE CS4 when the “mveaepreview.aex” plugin was installed without the I/O box connected. CS3 had no issues. Not saying it’s a fix but try dragging that plugin somewhere else temporarily then test to see if you still have a problem with “corrupt” clips.
