Activity › Forums › Adobe Premiere Pro › Matrox RTX 100 capture problem
Art White
October 6, 2005 at 3:20 amAaron, Andre,
..and all others. Thank you for the advice. A “Simple fix” considering the other complications I have been through. I changed that MB to add more RAM. Any suggestion as to which one is better for my configuration?
Art -
Andre Gagnon
October 6, 2005 at 6:11 am[artismobile] “Any suggestion as to which one is better for my configuration?”
If I was to buy a new Mobo now, I would probably go for the Intel D955XBK as tested by Matrox,
in order to have access to the dual-core CPU speed. Not cheap tough.https://www.matrox.com/video/support/rtx100xtremepro/rec/mb/intel D955XBK.cfm
Aaron Strader
October 6, 2005 at 1:30 pmIf you want to be able to use your exsisting hardware (cost effective, eh?) I heartily recommend the Asus P4P800 SE or the P4C800 boards.
They’re both easy to work with and quite reliable.
If you do want the serious upgrade, I side with Andre. The Dual core’s would be nice for using with After Effects and would be really nice for rendering unsupported effects on the timeline in premiere.
Art White
October 6, 2005 at 10:21 pmI’m sure all three suggestions will cure my problem. I’ve changed a few MB’s before but I’m a bit of a Freshman when it comes to dual core. Any complicated differences with the install? Hardware incompatibility with my current set up?
Thanks again for your help. It means much.
Art
