Activity Forums Adobe After Effects Matrox MXO2 LE anyone using it with AE CS5
  • Matrox MXO2 LE anyone using it with AE CS5
    Posted by Aaron Shadwell on January 9, 2012 at 5:48 am
    Hey guys by the sound of the write up on this box it makes it sound like AE will run in real time meaning NO ram previews any more?
    is that true?
    Matrox MXO2 LE
    Im running a mac pro 8 core 3GHz with 4 gb ram OS10.6
    thanks for reading!!!
    check out my rock band
    shadwellmusic.com
    Michael Szalapski replied 14 years, 8 months ago 2 Members · 1 Reply
  • Michael Szalapski
    January 9, 2012 at 3:11 pm
    No it is not true. That box is more for NLE’s. That’s why it refers mostly to the Mercury Playback Engine (Premiere Pro). The help it gives you with After Effects, as mentioned in this PDF on their site [link], is that it gives you “What You See Is What You Get”. Basically, it outputs your AE comp to an external screen (ideally a broadcast monitor) so you can see what the color will actually look like. (A regular computer monitor doesn’t show proper color.)
    Nowhere on the site does it say anything about speeding up your work in AE. All the speed increase (if any) would be in Premiere or when encoding a final compressed file in H.264.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
