Activity › Forums › Adobe Premiere Pro › Matrox MXO2 Broadcast monitoring with Mac and Premiere CS5.5
  • Matrox MXO2 Broadcast monitoring with Mac and Premiere CS5.5
    Posted by Keith Golinski on December 13, 2012 at 9:05 pm
    Hi everyone
    We’re making the switch from FCP 7 and so far the only problem I’m running into is getting my workspace to play on my external broadcast monitor through my Matrox MX02. I’ve installed all of the updates and the preview plays clip to the monitor just fine. I can also preview after effects through the Matrox but the workspace and timeline won’t play out to my monitor at all. I’m not finding any options to set the playback to be out through the matrox other than the player setting in the preferences. It’s got to be a setting somewhere. Thanks everyone for your time.
    -Keith Golinski
    fulvew.com
    Vic Philippossian replied 13 years, 9 months ago 3 Members · 5 Replies
  • Shane Ross
    December 14, 2012 at 1:35 am
    CS 5.5 had issues with all the third party cards. Upgrade to CS 6 and get the latest Matrox drivers.
    Shane
    Little Frog Post
  • Keith Golinski
    December 14, 2012 at 10:03 pm
    Thanks quick response Shane.
    -Keith
  • Vic Philippossian
    December 18, 2012 at 2:51 pm
    Hi Keith,
    My name is Vic, from Matrox support.
    For the Mac world, please confirm you have installed our 2.5 driver, and have your CS updates applied first.
    In premiere, when you build a new project, when ‘The New Sequence’ window opens on the Sequence Presets pane, under Available Presets, select the preset that matches the type of sequence that you want to create from the Matrox Presets folder.
    Now put some color bars on the timeline. Do you see them on our output monitor?
    If not, and lets say for example you are using HDMI out, go to system preferences, launch the Matrox icon, and go to the video out tab, set the HDMI output dropdown to 1080i, instead of main channel.
    Please keep us updated and let us know the type of cabling you are using, and if it is a direct connection.
    Best regards
    MVTS
  • Keith Golinski
    December 18, 2012 at 5:31 pm
    Thanks Vic!
    Yep 2.5.0.0033 installed.
    Sweet! That worked. It was the matrox preset. It would be great if you could change that after a project is started for machines that don’t have the matrox here but glad it works now. Thanks for the heads up.
    -Keith
  • Vic Philippossian
    December 18, 2012 at 5:38 pm
    Glad to hear Keith.
    If you have other inquiries, please feel free to use our user forums as well.
    Happy holidays.
    Regards
    MVTS
