Matrox MXO – HD Monitoring
I am trying to adapt our Quad G5 for XDCam work. There are a few things I’d like to do. First off, I’d like to view HD material on an external monitor for color correction. I’d also like to attach a plasma that is in a separate room (needs about 35′ of cable) for client screenings from Final Cut.
I’m looking at the Matrox MXO. Correct me if I’m wrong, but I don’t think I need the MXO2 since all of our acquisition will be done with the EX3.
We currently have a dual monitor display which I’d like to maintain. The MXO appears to occupy one of the DVI ports on the computer. I’m looking at the Matrox DualHead2Go system to split one of the DVI connections into 2. Sound good?
We have an old NTSC monitor. Will this be okay for color correction via the MXO’s downconverted footage? How much better would it be to upgrade to a 23″ Apple Cinema Display?
The computer has an nVidia GEForce 6600 display card. Is this powerful enough to run this configuration? Do I need to upgrade?
The final question is what kind of cables do I need? How should I connect the plasma 35′ away? For the NTSC monitor, what kind of cables should I use?
Renny
Quad G5 – 6gb RAM. FCP Studio 2. GEForce 6600. Sony EX3.
