Activity › Forums › Apple Final Cut Pro Legacy › Matrox MXO a capture card?
Posted by Tielman Dewaele on December 14, 2007 at 1:07 pmHey,
looked on the internet for the Matrox MXO.
I found some good info on it. But i was wandering iff this is a capture card aswell for HDV, others, ..
Yes i know about the monitor thing with the cinema apple screens.Can i connect other player/recorders on it.
SOrry for asking again, i want to be sure of what im buying.
Right know im not.T.
MacPRo intel quad core 2 G RAM
Iomega disks
AE CS3, PSD CS3, AI CS3
FCP 6.0 studio
C4d R10Shane Ross replied 18 years, 9 months ago 3 Members · 7 Replies -
Walter Biscardi
December 14, 2007 at 1:12 pmNo, display only.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Tielman Dewaele
December 14, 2007 at 1:19 pmThanx,
SO im want a card for dv, hdv, dvcam editing.
What do you think that would be the best?
An aja card. Ive got this player on my mind aswell.
Sony HVR-M15 HDV Recorder
Good?
Im desperate.T.
Iomega disks
FCP 6.0 studio
C4d R10 -
Walter Biscardi
December 14, 2007 at 1:28 pm[Mister T.] “SO im want a card for dv, hdv, dvcam editing.”
You don’t need a card for DV, DVCAM or HDV. You can edit all of those via Firewire.
Tielman Dewaele
December 14, 2007 at 1:58 pmyes but i want it to view on a monitor.
So far been told that HDV needs cant be viewed on a monitor without an aja, decklink…
What you thnk about that player?Thanx
Iomega disks
FCP 6.0 studio
C4d R10 -
Walter Biscardi
December 14, 2007 at 2:11 pm[Mister T.] “So far been told that HDV needs cant be viewed on a monitor without an aja, decklink…
What you thnk about that player?”You can’t view the HDV playback via Firewire. The Matrox does allow you to view HDV on an external display.
You can purchase an AJA Kona board if you want.
Tielman Dewaele
December 14, 2007 at 2:31 pmOk
Iff i purchase an aja kona card. Can i connect this player to this? Or does it just works with separate, this with firewire?I would have an nice setup with the player and the mxo, to view on external hdtv or cinema apple screens. This can view sd also i presume?
Maby i was thinking buying this first and then later on a aja kona card, so i can edit even beta /dvcprohd stuff iff ever needed?
Iomega disks
FCP 6.0 studio
C4d R10 -
Shane Ross
December 14, 2007 at 3:27 pmFor the record, the MXO doesn’t only output to a monitor, but also outputs to decks. It has DVI out, Component, Composite, HD SDI, and audio. It can output HD, and also downconvert to SD in real time for outputting HD to SD formats, or for viewing HD on an SD monitor (reference only). And it allows you to use an Apple Cinema Display as your HD monitor…displaying a broadcast quality image. With the other options, Kona and Decklink, you also need an HD monitor, and those are not cheap. This is why I tout the MXO…it is an inexpensive monitoring solution.
This is really handy if you have a laptop…but warning, it does NOT work with the newer MacBooks Pros. The ones with the NVIDIA cards. That is a bummer.
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.lfhd.net
