Activity › Forums › Apple Final Cut Pro Legacy › Matrox MXO
Matrox MXO
Posted by Curt Johnsen on August 29, 2006 at 11:36 amAny comments on this? If you were two years away form upgrading your desktop and own a G5 now, it might be a good investment because of the dvi conection rather than slot pci.
curtBen Holmes replied 20 years ago 4 Members · 3 Replies -
Walter Biscardi
August 29, 2006 at 12:14 pmOr your can look at an AJA Io which connects via Firewire. You can use this on the current machines, desktop and laptop, and future machines.
I’ve had one over two years now and it’s a great complement to our Kona systems. AJA has a long track record with FCP and has tremendous support and is a favorite of broadcast companies. For my money, I’d stick with AJA.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Ben Holmes
August 29, 2006 at 2:42 pmIf you believe what Matrox say about the quality (hoping to see it at IBC) then it depends whether or not you need a card that’ll do capture as well. If you don’t, and you’re not interested in similar DVI-HD/SD-SDI products from AJA or Blackmagic then fine. Mac users are understandably nervous of Matrox. The claims about reclocking a DVI output so that it’s good enough for broadcast/edit to tape are interesting. Certainly, I wouldn’t use our AJA DVI-HD-SDI box for that…
I was considering it so that we could feed an LCD HDTV via re-clocked DVI for clients – obviously we use CRT HD monitors for ourselves, but it’s an alternative for our current systems. If you had a requirement to make presentations or other grapics available in a broadcast enviroment, it could also act as a cheap scan-converter…
If you just want an SD out, you could just buy a $299 Blackmagic card anyway. Couldn’t you fit that in your G5, or is it full? Never managed that.
Read the other thread – it’s an interesting discussion involving people who tested it. And I used to be an RTMac user. Forgive and forget? We’ll see.
Ben
Editec Broadcast Editing Ltd
EVS & FCP specialists for live OB operations.“The Supercar Run” now available for international distribution from http://www.electricsky.com
See you at IBC – we’re there with our FCP/replay truck…
