Activity Forums Adobe Premiere Pro Matrox effects don’t work
  • Matrox effects don’t work
    Posted by Zvi Twersky on May 14, 2007 at 4:57 pm
    We recently formated the computer and rebuild it.
    I downloaded and installed the latest intsall pack for out Matrox video card (I think it’s RX-100)
    I see the matrox effects in the effects window, but when I try to drag one to a clip, nothing happens. Also, when I try to open a project that was build with Matrox effects on another computer, Adobe says that it’s missing the Matrox effects.
    What should I do?
    Paul Southil replied 18 years ago 5 Members · 6 Replies
  • Harm Millaard
    May 14, 2007 at 5:15 pm
    Just a very personal opinion: Get rid of the Matrox card. It is great as a door stopper.
  • Zvi Twersky
    May 14, 2007 at 5:24 pm
    I just work here. I’m not the boss. 🙂
  • Andre Gagnon
    May 14, 2007 at 7:26 pm
    Did you select a Matrox Project when Premiere asked you to choose a project preset? You have this choice on the first multiple choice screen that you have when you launch Premiere.
    If you don’t, you are in a mode where the results will be the same as if you had not installed the Matrox Software and Hardware although the Matrox effects still appear in the menu.
  • Zvi Twersky
    May 15, 2007 at 4:33 am
    Thanks so much! Yes that worked!
    But on the newer computer, we have a newer Matrox, (I think it’s called RX-200 instead of RX-100) and there are SO many more effects! Is there any way to add these effects so that the RX-100 will recognize them? When I open a project I made in Matrox RX-200 on the newer computer, it says that it’s missing filters (effects).
    Thank you!
  • Ron Shook
    May 15, 2007 at 6:30 am
    Zvi,
    [Zvi_Twersky] “I think it’s called RX-200”
    No such animal. Probably the RT.X2.
    [Zvi_Twersky] “When I open a project I made in Matrox RX-200 on the newer computer, it says that it’s missing filters (effects).”
    Rule of thumb: You can usually go forward with NLEs, but you can almost never go back. Either go from the RTX100 to the RT.X2 or get another RT.X2 if you want to be able to pass projects back and forth.
    BTW, you’re on the wrong Forum. Go to the Matrox Editing COW Forum for questions about Matrox hardware systems.
    Ron Shook
  • Paul Southil
    September 2, 2008 at 2:59 pm
    Thank you andre. It just worked properly. thank you for your advise.
    regards
    paul
