  • Posted by Paul Southil on September 2, 2008 at 10:06 am
    Dear Friends:
    I had to reformat my pc and i have re installed premier pro and matrox rx 100. Harware and software installed properly and it shows in premier effect plug ins. but when i drag a effect on the timeline
    matrox effects are not happening. and also my tv out is not working.
    when i play a dvd in the pc it is playing in the pc as well as i can see it in the tv monitor. anyone can fix my porblems pls. I am stuck. Thank you.
    Paul
    Jeff Pulera replied 17 years, 12 months ago 2 Members · 1 Reply
  • Jeff Pulera
    September 2, 2008 at 1:48 pm
    Hi Paul,
    Make sure that when you start Premiere that you are choosing a Matrox project preset. You may have been used to that being the “default” and it has now likely returned to “DV 48K” which is a Premiere Preset so Matrox effects and BOB output will not work.
    Another possibility is that if the RT.X100 card was in PC during Windows re-install is that generic 1394 drivers got loaded for the RT.X100 hardware. You may need to uninstall/reinstall Matrox hardware and drivers.
    Jeff Pulera
    Safe Harbor Computers
    http://www.sharbor.com
