Activity Forums Adobe After Effects matrix effect
  • matrix effect
    Posted by Dave Fraser on July 28, 2008 at 1:38 pm
    hey guys,
    quite similar to the last post actually.
    i have 178 stills, 100 pix wide. i wanted to create a grid using all the stills. i’ve tried using the matrix script but this doesn’t give me a good enough grid. was wondering if anyone knew of another way of creating this other then using photoshop and manually placing each still where i want?
    i need each picture and butt together without any gaps between each image. i’ve posted this on the ae expressions forum also, to see if the bofins there have any bright ideas.
    cheers
    Dave Fraser
    Motion Graphics Artist
    Big Button Media LTD
    http://www.bigbutton.tv
    Thad Ciechanowski replied 18 years, 1 month ago 2 Members · 2 Replies
  • Dave Fraser
    July 28, 2008 at 2:42 pm
    hey guys,
    a good man called lloyd helped me with this question.
    if anyone is interested, this was his response. it worked a charm.
    Hi Dave,
    Have you tried my Layers2Grid script?
    https://aescripts.com/2006/06/12/layers2grid/
    -Lloyd
    Dave Fraser
  • Thad Ciechanowski
    July 28, 2008 at 3:28 pm
    Try using
    “align & distribute”, you can open up it’s window under “window/align % distribute”. The icons to distribute and align are vague and although they may have improved in CS3 you’re going to have to figure out what does what by trial and error.
    The other option is to do your grid placement in AE instead of Photoshop. Save yourself a few steps.
    Good Luck
