Activity Forums Adobe After Effects Expressions Math.ceil finding the highest value of a key framed property over entire composition?
  • Math.ceil finding the highest value of a key framed property over entire composition?
    Posted by James Ronan on February 3, 2016 at 9:34 am
    Hello all.
    Is it possible to have a Math.ceil expression or something else that finds the highest value of keyframes within a layers property?
    e.g.
    SliderA animates from 0 – 100 – 50 over 3 seconds.
    Slider B has a Math.ceil expression looking at SliderA. and knows that 100 is the highest value it will be over 3 seconds so has a constant value of 100.
    Not sure if that is even possible but if it is it would be super handy!
    James
    James Ronan replied 10 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 3, 2016 at 2:31 pm
    You’d have to loop through the keyframes. Something like this should work:
    s = effect("SliderA")("Slider");
    if (s.numKeys > 0){
    maxVal = -9999999;
    for (i = 1; i <= s.numKeys; i++){
    maxVal = Math.max(maxVal,s.key(i).value);
    maxVal
    }else
    s.value
    Dan
  • James Ronan
    February 3, 2016 at 4:45 pm
    Wow! Yes, That is perfect!
    This works brilliantly! Thank you so much!
