Activity Forums Adobe After Effects Expressions Math.sin wave cycle
  • Math.sin wave cycle
    Posted by Alex Andry on June 20, 2022 at 11:50 am
    Hello everyone,
    is it possible to make a cycle through the length of the composition from this expression?
    Thank you!
    S = effect(“Speed”)(“Slider”);
    A = effect(“Amp”)(“Slider”);
    F = effect(“Frequency”)(“Slider”);
    R = effect(“Resolution”)(“Slider”);
    W = effect(“Width”)(“Slider”);
    P = [];
    for (i=0; i<R; i++) {
    P.push([W/R*i, Math.cos(time*S+i / (R/F))*A]);}
    createPath(P, [], [], false)
    Alex Andry replied 4 years, 3 months ago 2 Members · 2 Replies
  • Filip Vandueren
    June 20, 2022 at 12:41 pm
    Try this, with a slider “Cycles” instead of “Speed” that you set to how many cycles you want to occur in the comp’s duration, then:
    C = effect("Cycles")("Slider");
    S = (Math.PI*2*C)/thisComp.duration;
    A = effect("Amp")("Slider");
    F = effect("Frequency")("Slider");
    R = effect("Resolution")("Slider");
    W = effect("Width")("Slider");
    P = [];
  • Alex Andry
    June 20, 2022 at 1:03 pm
    Perfect!
    Thank you Filip!
    I tried to solve it in a different way and confused myself.
