Activity › Forums › Adobe After Effects Expressions › Math.sin easing?
  • Dan Ebberts
    November 5, 2020 at 7:15 pm
    Hard to guess what you’re after exactly, but maybe something like this:
    freq = 2;
    amp = 100;
    period = 1/freq;
    t = time%period;
    tt = ease(t,0,period,0,period);
    amp*Math.sin(freq*tt*Math.PI*2)
  • Niek Pronk
    November 10, 2020 at 1:01 pm
    Hi Dan,
    thank you so much for your reply. It’s not really doing what I wanted though.
    Im trying to keep a pulse in my animation and let the Math.sin expression dictate that pulse. My expression is as follows:
    x=value[0];
    a=thisComp.layer(“SLIDER controls”).effect(“Amplitude 1”)(“Slider”);
    f=1.8461538462;
    t=time-inPoint;
    y=Math.sin(t*2*Math.PI*f/thisComp.layer(“SLIDER controls”).effect(“Speed”)(“Slider”))*a;
    [x,y]
    It is generating a nice pulse (see my attached screenshot) but I would like the top and bottom half of the pulse to have more ease-in and ease-out. Is this possible?
    Thanks again so much
    Niek
  • Filip Vandueren
    November 10, 2020 at 1:44 pm
    s = Math.sin(t);
    Math.pow(s, 0.5) * Math.sign(s);
    as that 0.5 will tend to 0, the sin will flatten the tops and bottoms of the sinewave more and more, approaching a square wave. Making the value of the power larger than 1 will make it approach a ‘needle pulse’ as it tends to infinity.
    If you are running the Legacy javascript engine. Math.sign() isnet supported and you would need this:
    s = Math.sin(t);
    Math.pow(s, 0.5) * (s<0 ? -1:1);
    replace the “t” with your formula of course.
  • Niek Pronk
    November 10, 2020 at 1:55 pm
    Hi Filip,
    thanks a lot for your reply. Not sure if I am applying your suggestion correctly. Does it mean I paste your suggestion after I’ve defined y? Like this:
    x=value[0];
    f=1.8461538462;
    t=time-inPoint;
    Math.pow(y, 0.5) * Math.sign(y);
    [x,y]
    Because that unfortunately doesn’t change the pulse of the math.sin. But maybe I am doing something wrong here..?
  • Filip Vandueren
    November 10, 2020 at 4:02 pm
    You didn’t assign the new calculation to anything yet, so the y indeed stays unchanged.
    The Math.pow should be done on a -1 to +1 sin value, so wait with mulitplying *a untill afterwards.
    Like this:
    y=Math.sin(t*2*Math.PI*f/thisComp.layer("SLIDER controls").effect("Speed")("Slider"));
    y=Math.pow(y, 0.5) * Math.sign(y) * a;
    [x,y]
  • Niek Pronk
    November 12, 2020 at 8:10 am
    Thanks for your help Filip. Unfortunately it’s giving me an error and the movement is somehow only going up..
  • Filip Vandueren
    November 12, 2020 at 9:13 am
    Can you tell me the error ?
    Probably you are on an the legacy Javascript engine that doesn’t support Math.sign
    replace it with (s<0 ? -1:1)
  • Niek Pronk
    November 12, 2020 at 11:06 am
    It is still only completing the top half of the pulse. AE tells me it cannot produce a numeric value for [x,y]
    this is what i have now:
    y=Math.sin(t*2*Math.PI*f/thisComp.layer(“SLIDER controls”).effect(“Speed”)(“Slider”));
    y=Math.pow(y, 0.5) * (y<0 ? -1:1) * a;
  • Filip Vandueren
    November 14, 2020 at 2:06 pm
    Sorry, i forgot to include Math.abs(y) inside the power !
    x=value[0];
    a=thisComp.layer("SLIDER controls").effect("Amplitude 1")("Slider");
    f=1.8461538462;
    t=time-inPoint;
    y=Math.pow(Math.abs(y), 0.5) * Math.sign(y) * a;
    [x,240+y];
