Materias showing in viewport but not rendering?
As you see at first it looks like the textures are correct but then when I try to render this happens. When I frist create a new project everyting works fine but then after a cuple of times stops working. I’m using corona to render
Here to see the sreenshots:
https://i.imgur.com/mJdL8Xv.png
https://i.imgur.com/Et7v3Dt.png
