Activity Forums Maxon Cinema 4D Material transition across a single object
  • Material transition across a single object
    Posted by David Gruwier on February 21, 2014 at 12:37 am
    Is it possible to do a material transition in C4D over a single object, using something similar to effectors?
    I need to be able to control the transition using a null or something similar.
    My initial idea was to use black/white mograph colors on the alpha, and a plain effector going from white to black. But that only works per object, and not on a vertex/point basis, so I can’t make the material move across the object.
    My other though is to use some kind of vertex painting, but I can’t figure out how I would link it to a null or do it based on the hierarchy somehow.
    My last resort would be to use a gradient and animate the coordinates or something like that, but I would have to do it manually, and my animation is pretty complex.
    Any ideas? Hope it makes sense 🙂
    Darby Edelen replied 12 years, 7 months ago 3 Members · 3 Replies
