Activity Forums Maxon Cinema 4D Material textures neon Flash Flashing on/off expresso?
  • Material textures neon Flash Flashing on/off expresso?
    Posted by Randal Radabaugh on November 29, 2010 at 10:27 pm
    Pardon my rash of questions. I am working on a large project.
    am sure this is old hat by posts I have seen.
    1. what is the simple answer to flash a neon material/texture-not lights, on and off.I ask this in case I cannot work it out.
    2. To have this animate for at least over 1000 frames? using expresso?
    3. with an expresso rig for actual light/visibilty already set, how in expresso would I add the material-texture to go on or off.
    I used a flashing lights tut as a guide-but objects are spline/tubes(Sweep nurbs)with Neon material.
    Basicallly how can I substitute the material for the light visibility
    as in this tut— https://www.jonnychapps.com/create-flashing-lights-in-cinema-4d/
    I thought it easier to use material channels than to create actual lights.
    There are 9 splines of tubes grouped in three’s, and each group of three is separate flash on/off.
    Pretty sure expresso is required for controller,and have not gotten
    to that point yet in learning.
    Am grateful for COW and appreciate any assist.
    Randal Radabaugh replied 15 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
