Activity › Forums › Maxon Cinema 4D › Material Preview
  • Material Preview
    Posted by Caleb Thomas on August 20, 2008 at 9:28 pm
    Where can I find icons or previews of my materials? I’m trying to find one now but am having to load the material, add it to the nurb, and then try again if I don’t like it.
    Caleb Thomas replied 18 years, 1 month ago 2 Members · 2 Replies
  • Randy Johnson
    August 21, 2008 at 11:34 am
    You can put the material on the object and work on the material at the same time and see the changes after each operation. Assuming you have textures turned on in your viewer.
    /randy
  • Caleb Thomas
    August 21, 2008 at 2:35 pm
    Thank Randy, it just seems like there should be a better way. If you go through all of wood or metal materials trying to find the right one you’ll see. It gets annoying.
